Добавлено: Чт Ноя 12, 2026 10:48 pm Заголовок сообщения: Find day with date |
Article about find day with date:
If you are looking for an Excel function to get day of week from date
you've landed on the right page. This tutorial will teach you how to use the WEEKDAY formula in Excel to convert a date to a weekday name
filter
highlight and count weekends or workdays
and more. There are a variety of functions to work with dates in Excel.
>>> GO TO SITE <<<
The day of week function (WEEKDAY) is particularly useful for planning and scheduling
for example to determine the timeframe of a project and automatically remove weekends from the total. So
let's run through the examples one-at-a-time and see how they can help you cope with various date-related tasks in Excel. WEEKDAY - Excel function for day of week. The Excel WEEKDAY function is used to return the day of the week from a given date. The result is an integer
ranging from 1 (Sunday) to 7 (Saturday) by default. If your business logic requires a different enumeration
you can configure the formula to start counting with any other day of week. The WEEKDAY function is available in all versions of Excel 365 through 2000. The syntax of the WEEKDAY function is as follows: Serial_number (required) - the date that you want to convert to the weekday number. It can be supplied as a serial number representing the date
as a text string in the format that Excel understands
as a reference to the cell containing the date
or by using the DATE function. Return_type (optional) - determines what day of the week to use as the first day. If omitted
defaults to the Sun-Sat week. Here is a list of all supported return_type values: Return_type Number returned 1 or omitted From 1 (Sunday) to 7 (Saturday) 2 From 1 (Monday) to 7 (Sunday) 3 From 0 (Monday) to 6 (Sunday) 11 From 1 (Monday) to 7 (Sunday) 12 From 1 (Tuesday) to 7 (Monday) 13 From 1 (Wednesday) to 7 (Tuesday) 14 From 1 (Thursday) to 7 (Wednesday) 15 From 1 (Friday) to 7 (Thursday) 16 From 1 (Saturday) to 7 (Friday) 17 From 1 (Sunday) to 7 (Saturday) Note. The return_type values 11 through 17 were introduced in Excel 2010 and therefore they cannot be used in earlier versions. Basic WEEKDAY formula in Excel. For starters
let's see how to use the WEEKDAY formula in its simplest form to get the day number from date. For example
to get the weekday from date in C4 with the default Sunday - Saturday week
the formula is: If you have a serial number representing the date (e.g. brought by the DATEVALUE function)
you can enter that number directly in the formula: Also
you can type the date as a text string enclosed in quotation marks directly in the formula. Just be sure to use the date format that Excel expects and can interpret: Or
supply the source date in a 100% reliable way using the DATE function: To use the day mapping other than the default Sun-Sat
enter an appropriate number in the second argument. For example
to start counting days from Monday
the formula is: In the image below
all the formulas return the day of the week corresponding to January 1
2025
which is stored as the number 45658 internally in Excel. Depending on the value set in the second argument
the formulas output different results. At first sight
it may seem that the numbers returned by the WEEKDAY function have very little practical sense. But let's look at it from a different angle and discuss some formulas that solve real-life tasks. How to convert Excel date to weekday name. By design
the Excel WEEKDAY function returns the day of the week as a number. To turn the weekday number into the day name
employ the TEXT function. To get full day names
use the "dddd" format code: To return abbreviated day names
the format code is "ddd": For example
to convert the date in A3 to the weekday name
the formula is: Please note that in this formula
you should use WEEKDAY with only one argument
serial_number . Do not include return_type
even if your week starts on a day other than Sunday. Actually
the WEEKDAY function is unnecessary for this formula. The TEXT function alone would work nicely: Though
we often think of WEEKDAY as the day of week function
which might make this formula easier to remember.
south west bins collection dates 2021
how do i find someone's date of birth
how to find out the last day i worked |
