Добавлено: Пн Авг 31, 2026 2:56 pm Заголовок сообщения: скачать сайт знакомств кисмиа |
Статья о скачать сайт знакомств кисмиа:
Каждый день тысячи людей со всего мира,
Скачать Kismia - знакомство с одинокими поблизости APK. Read phone status and identity : • Allows the app to access the phone features of the device. This permission allows the app to determine the phone number and device IDs, whether a call is active, and the remote number connected by a call.
. Modify or delete the contents of your usb storage : • Allows the app to write to the USB storage. . Read the contents of your usb storage: • Allows the app to read the contents of your USB storage.. Precise location (gps and network-based) : • Allows the app to get your precise location using the Global Positioning System (GPS) or network location sources such as cell towers and Wi-Fi. These location services must be turned on and available to your device for the app to use them. Apps may use this to determine where you are, and may consume additional battery power. . Approximate location (network-based) : • Allows the app to get your approximate location. This location is derived by location services using network location sources such as cell towers and Wi-Fi. These location services must be turned on and available to your device for the app to use them. Apps may use this to determine approximately where you are. . Modify your contacts : • Allows the app to modify the data about your contacts stored on your device, including the frequency with which you've called, emailed, or communicated in other ways with specific contacts. This permission allows apps to delete contact data. . Read your contacts : • Allows the app to read data about your contacts stored on your device, including the frequency with which you've called, emailed, or communicated in other ways with specific individuals. This permission allows apps to save your contact data, and malicious apps may share contact data without your knowledge. . Full network access : • Allows the app to create network sockets and use custom network protocols. The browser and other applications provide means to send data to the internet, so this permission is not required to send data to the internet. . View network connections: • Allows the app to view information about network connections such as which networks exist and are connected.. Receive data from internet: • Allows apps to accept cloud to device messages sent by the app's service. Using this service will incur data usage. Malicious apps could cause excess data usage.. Effects on battery life: Prevent device from sleeping: • Allows the app to prevent the device from going to sleep.. Control vibration: • Allows the app to control the vibrator.. Run at startup: • Allows the app to have itself started as soon as the system has finished booting. This can make it take longer to start the device and allow the app to slow down the overall device by always running.. |
