(!!Flirt!!^) how do i add friends on find my friends
СообщениеДобавлено: Пт Ноя 13, 2026 10:50 pm    Заголовок сообщения: (!!Flirt!!^) how do i add friends on find my friends Ответить с цитатой
Article about how do i add friends on find my friends:
Note: Do not sync your information multiple times in a row. If the issue persists after attempting to manually sync your data, please consider trying the following troubleshooting tips. • Make sure that there's at least 5 GB of free space on your device before syncing your friend and group data.
Click here for How do i add friends on find my friends
• Change your theme to the Original theme. Note: - Tap the Home tab > Settings > Themes > My Themes and apply the Original theme. - Tap here to go to Settings from your smartphone. • Delete the group chat you're having issues with and then ask a group member to send you a chat message. • Leave the group chat and then join it again. Please keep in mind that performing the steps above will delete your chat history. In the future, please consider saving important chat history in text format. Note: Saved content cannot be restored as chat history. Was this page helpful? Thank you for your feedback. Let us know if we can make it better. Note: - Do not enter any personal information. - We cannot respond to comments received from this form. Sorry about that. What went wrong? Note: - Do not enter any personal information. - We cannot respond to comments received from this form. Friend list display issues. If there are display issues with your friend list, refer to the section below based on your situation. Settings are not applied/Friend and profile information differs from what others see E.g. You receive chat messages from someone you blocked, The group name you see differs from the name your friends see. This happens when your device cannot auto-sync with our servers for some reason. Update LINE to the latest version and restart your device. If the issue persists after updating LINE to the latest version and restarting your device, try manually syncing your friend and group data yourself by tapping the link below from the smartphone that you use with LINE. Note: Do not sync your information multiple times in a row. Affected information: Friends, groups, group invitations, friend recommendations, favorites, hidden accounts, and blocked accounts Issues related to your device's contacts. Friends' names don't appear as they're registered in your device's contacts Important: The contents of this section only apply to LINE accounts created with LINE versions earlier than 13.11.0 if you're not using LINE in Hong Kong, Japan, Korea, Taiwan, or Thailand. Your friends' names on LINE will appear as they are registered in your device's contacts if: • They registered their LINE accounts with the phone number registered in your device's contacts. • You have Auto-add friends turned on (or you had it on when you added your friends). If you added your friends with a method other than the above (e.g. via ID search, QR code), they'll appear with the name they set on LINE. Contacts on my device don't appear in my friend list This may be because: • You or your friend have the Allow others to add me setting turned off. • You were hidden or blocked by them. • They appear in your friend recommendations. For more details, please refer to the following Help pages. Friends' names do not appear properly If the friend whose name does not appear properly is saved in your device's contacts, it's possible their name contained an emoji when it was saved. Check your contacts list, and if your friend's name was saved with an emoji, please try deleting it. If the issue persists after trying the suggestion above, try manually syncing your friend and group data yourself by tapping the following link from the smartphone that you use with LINE. Note: Do not sync your information multiple times in a row. Repairing friend and group data Friends don't appear/have disappeared This may be because: • They deleted their accounts. • You hid, blocked, or deleted their accounts. • Your LINE account was not transferred properly. Note: You cannot undo deleting a friend. In this case, please add them again. Was this page helpful? Thank you for your feedback. Let us know if we can make it better. Note: - Do not enter any personal information. - We cannot respond to comments received from this form. Sorry about that. What went wrong? Note: - Do not enter any personal information. - We cannot respond to comments received from this form. My friend's account appears, but a different person is using it. Important: The contents of this article only apply to LINE accounts created with LINE versions earlier than 13.11.0 if you're not using LINE in Hong Kong, Japan, Korea, Taiwan, or Thailand. If the owner of a phone number registered in your device's contacts has changed or if the phone number is incorrectly registered in your contacts, it will create a situation in which the LINE account of a friend that appears in your friend list is actually being used by a different person. - Syncing LINE with your device's contacts is a feature that automatically adds friends registered in your contacts as friends on LINE. - You can see the name someone has set on LINE for their account by tapping the pencil icon next to their display name. If you see an unfamiliar name, it's possible that your friend has already changed their phone number. Issues happening on your LINE account • Someone who doesn't use LINE appears in your friend list Make sure your friend's phone number is current and registered correctly in your device's contacts. • An account that appears in your friend list belongs to someone you don't know Check whether you've registered multiple phone numbers for your friend in your device's contacts. • The name of someone in your friend list suddenly changed Check whether you changed their registered name in your device's contacts. • There's an account that appears in your friend list under your name Check whether an old phone number from a previous contract is registered under your name in your device's contacts. Issues happening on another person's device • An account or multiple accounts under your name appear in your friend's LINE account despite not using the service Check whether your old phone number from a previous contract is registered in the contacts of your friend's device. • Someone you don't know sees your name on their LINE account when you register your phone number for a new contact on LINE Your phone number for a new contract (that previously belonged to someone else) is likely registered in the contacts of the unfamiliar person's device. - If someone you don't know appears in your friend list, you can delete them after hiding or blocking them. - We recommend turning on the Filter messages setting to prevent receiving messages from users you don't know. If you're still having issues after you've confirmed everything above, your device information may not be synced with the information on LINE's servers. If you're unable to sync your device information with LINE's servers, refer to the following Help article. Was this page helpful? Thank you for your feedback. Let us know if we can make it better. Note: - Do not enter any personal information. - We cannot respond to comments received from this form. Sorry about that. What went wrong? Note: - Do not enter any personal information. - We cannot respond to comments received from this form. Why does a blocked or removed friend still appear in my game rankings? The reason will differ for each game. Please start the game and contact the LINE Games team using the inquiry form found inside the app. Was this page helpful? Thank you for your feedback. Let us know if we can make it better. Note: - Do not enter any personal information. - We cannot respond to comments received from this form. Sorry about that. What went wrong? Note: - Do not enter any personal information. - We cannot respond to comments received from this form. I verified a Japanese phone number and can't search for IDs/phone numbers because age verification is required.
how do you add people to find my iphone
how do you add someone to find my iphone
how do i add someone on find my iphone
